Cristiano Alves Posted March 9, 2024 Share Posted March 9, 2024 Hello Guys, I would like to understand if it's possible and how I can create a "parametrically rotatable object." The goal is to implement it for some objects like Adjustable Barriers for crowd control, but I believe it could have many more potential uses. One of the main reasons I switched to Vectorworks was precisely because of the ability for objects to have parametric transformation capabilities. However, for the past two days, I've been back to "the old ways," manually edit objects for different opening angles (in this case). Is it possible to build this type of object ourselves? Quote Link to comment
Pat Stanford Posted March 9, 2024 Share Posted March 9, 2024 This is a perfect use case for making a Marionette object. Marionette or Vectorscript/Python or SDK are the way you make parametric objects for yourself. There is no button to take an object you have drawn and just say "make this parametric" 1 Quote Link to comment
Cristiano Alves Posted November 15, 2024 Author Share Posted November 15, 2024 On 3/9/2024 at 8:16 PM, Pat Stanford said: This is a perfect use case for making a Marionette object. Marionette or Vectorscript/Python or SDK are the way you make parametric objects for yourself. There is no button to take an object you have drawn and just say "make this parametric" I'm back to this problem. At the time I investigated a little about Marionette objects, It seemed powerful to me. I saw tutorials applied to 2D objects, I didn't find much information about applying to objects from our libraries. Could you direct me to a more correct path? Quote Link to comment
