TurtleBuilds Posted March 1, 2024 Share Posted March 1, 2024 I am working on creating a plug in object to lay out a stage and I would like it to adjust the leg heights according to the ground elevation. I am thinking that the ground elevation should be a NURBS surface to show the change in elevation. How would I get the elevation, the z point, at point (x,y)? How do I detect when an object passes through a surface? Any help is appreciated Quote Link to comment
AlHanson Posted March 3, 2024 Share Posted March 3, 2024 You basically answered your own question already. 😅 Look at vs.GetZatXY. It can be a little flakey from my experience though, and works best when you specify the object handle rather than leaving it as None and having it figure things out for you. Even when specifying the object to check against I occasionally still get incorrect results which cause some situational funkiness. 1 Quote Link to comment
TurtleBuilds Posted March 4, 2024 Author Share Posted March 4, 2024 Well see now, that would be just too easy 🤣 I'll give it a shot. Thank you for your help. 1 Quote Link to comment
TurtleBuilds Posted March 4, 2024 Author Share Posted March 4, 2024 So perhaps I am not understanding this correctly. I attempted to use vs.GetZatXY() and the symbols placed at this value are inserting below the "ground" polygon. I have tried to make the ground a NURBS surface instead but did not change the results. I suspect that I am doing something wrong in terms of reference points, but am not sure what that would be. I attached the file in the event of the likelihood that it's user error. 🤣 FootPlacement.vwx Quote Link to comment
