Control Hardscape Tag ID value by style
Is there a way to assign a Tag ID value ta a certain style of Hardscape? So that I can control the tag of all drawn hardscape from within the style?
So far I have a custom record assigned to all hardscape styles but I'd also want to control the values in the record from the style. Preferable just like it's done in Plants, where I can also control if the Tag ID is set by instance or by Style. I guess this is basically a question if I can have records fields in general be set to By Instance or By Style? Or is there another way?
I have come up with a solution of assigning every style to different class and coupling that class to certain values via the Data Manager. Seems unnecessarily cumbersome though, so I was hoping for a better solution?
