matto Posted May 14, 2003 Share Posted May 14, 2003 i wish i may... i wish i might... have an option in the multiple duplicate dialog box to leave the orginal objects selected once completed. instead of the created objects. or as well as the created objects. ok thats three options in all. maybe in pop-up menu. that way i can then duplicate the same objects agian in the other direction. best regards matt Quote Link to comment
0 P Retondo Posted May 14, 2003 Share Posted May 14, 2003 If by "other direction" you mean at 90 degrees, use the rectangular array option to get everything in one step. Quote Link to comment
0 Dan Kessler Posted May 14, 2003 Share Posted May 14, 2003 I couldn't agree more with Matt. It's incredibly frustrating to have the resulting objects selected after an offset. I brought up this same issue a while back. Here's the thread: http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=12;t=002012 Dan Quote Link to comment
0 matto Posted May 15, 2003 Author Share Posted May 15, 2003 ok rectangular array i use that all the time but it's not what i'm looking for by this. as you can imagine rectanglar array gives a rectanglar mass of duplicates. what i'm suggesting means you could easily do an 'L' shape of duplicates. or draw an object in the center of a room then put spaced duplicates left and then right of the original. or stop that annoying thing of all the duplicates in a rectanglar array being selected except the original.if there is several objects in the original or it was a fiddly selection to start with. as it now you have to redo that selection before you can tweak the position enmass. oh one more option -that just the last of the duplicates is selected. hope that makes sense matt Quote Link to comment
0 Katerina Posted May 23, 2003 Share Posted May 23, 2003 I know you might be looking for something different, but if this helps you for now any try the Duplicate/Multiple command found on VectorDepot Quote Link to comment
matto
i wish i may...
i wish i might...
best regards
matt
4 answers to this question
