In a site modelling project these two parameters, height and slope, are frequently used and shown. They both have their own separate use.
Is should be possible for both to have their own object attributes - in other words the user should be able to assign a class for example:
- Height new or existing
- Slope/grade new or existing
WISH:
1. Open Edge Line, Planar Pad & Pad with Retaining Edge
Add Assign Class option to the Planer PadSlope settings. This makes it possible when showing the Slope value its appearance is consistent when using are Slope definitions in the file. This for the Site Modifiers Open Edge Line, Planar Pad & Pad with Retaining Edge and for Hardscape with Planar Pad configuration
2. Aligned & Path objects incl. Classes for Profiles, Longitudinal Profile, or Transverse Profiles
Change the assign Class options so one can define the appearance of Slope and one defines the appearance of Height by adding:
- Class Height values
- Class Slope value
- Class Profile
Then the Show-option boxes can be deleted and replaced by changing the visibility of the Class. This allows these values to be shown consistently throughout the drawing and eliminates to need to set this separately for every single object.
Carol Reznor
Hi
WISH:
Add Assign Class option to the Planer Pad Slope settings. This makes it possible when showing the Slope value its appearance is consistent when using are Slope definitions in the file. This for the Site Modifiers Open Edge Line, Planar Pad & Pad with Retaining Edge and for Hardscape with Planar Pad configuration
- Class Slope value
- Class Profile
Thank you
0 answers to this question
