Position Label Problem
When I try to use a position Label with a summary, the position Name is not vertically centered in its box. Instead it is set too low and the bottom of the text is cut off. Changing the font size does not seem to help. It appears to be a text alignment problem, but I can not find anyway to change it.
Can you help?
Thanks.
Bill Berner
