Wall modification - perpendicular allowed?
1 hour ago, jason schneider said:
I hadn't thought of that, but it doesn't seem to work with doors. ...Unless I'm doing something wrong? (The two green boxes are solids placed in the wall to test the "Fit to Objects" approach.)
I believe you would need to use a 'dummy' object in a hidden class or layer to do it. But @shorter is right: this way you will achieve vertical sides to the cut-out if you want to save some sessions with your therapist! Personally I reshape Walls all the time using the Edit Wall tool + have never had any ill effects as a result of the sides being off-plumb i.e. everything looks correct in the viewports whether 3D views, elevations or sections. It just 'feels' wrong when you're doing it...
