PDF Generation Error using Publishing
chrisjones
There appears to be an error when publishing PDF drawings with a reference file.
What appears to happen is if you orientate the drawing to fit a sheet layer, there reference file appears to default to it's original orientation when a PDF is generated, regardless of it being correct on the drawing.   Will there be an update to correct this bug?
I cannot attach an image due to this being a public forum, but can provide an example of the drawing to the VW technical team on request.
1 answer to this question
