lyndirk Posted February 7 Share Posted February 7 Hello! Having trouble with my 2023 vectorworks, and in need of a file to be exported as a 2022 file (File>Export>As 2022 Vectorworks file) if I send it over. My 2023 vworks is inoperable at the moment. Thanks! Quote Link to comment
Vectorworks, Inc Employee Domas Posted February 7 Vectorworks, Inc Employee Share Posted February 7 Hello @lyndirk, Im sure someone can assist in the forum, as well as I can export the file for you. What i would recommend to do is to open a support request through your customers portal making the same request and paste the link of this forum thread. You can find the request form under the link below: customers.vectorworks.net After you will log in head down to the support tab and one of the links towards the bottom of the page will be to open a support request. I would like to ask, what is happening with 2023 for you? Maybe you could explain the problem and instead of jumping to an older version we can find a better solution so you could keep on using your Vectorworks 2023? Quote Link to comment
