Cookie_NZ Posted February 5, 2024 Share Posted February 5, 2024 (edited) Is there a command/tool to attach a light to a hanging position without the lighting device snapping to the position? The Attach to Rigging Object... from the contextual menu will move the lighting device to the hanging position. I'm aware of the Auto-position settings in the Spotlight preferences: But these functions can cause the lighting device to snap to the wrong piece of geometry, particularly when working with booms/side lighting positions. The lighting device will snap to the vertical pipe and not the boom arms (the boom arms are Point loads in the drawing below): Cheers, Cookie Edited February 5, 2024 by Cookie_NZ Didn't note the 'Attached to rigging object' function. Quote Link to comment
markdd Posted February 5, 2024 Share Posted February 5, 2024 Yes - When you run this command you should see a dialog with a list of Lighting devices with Checkmarks. Uncheck the device you want to stay in place and an association will be made without it moving. That's the theory anyway! Quote Link to comment
Cookie_NZ Posted February 5, 2024 Author Share Posted February 5, 2024 Hi Mark, Works like a charm! Thanks as ever. Cheers, Cookie Quote Link to comment
