zaklee
Wall Styles
Wouldn't it be great if you could create a group of wall styles? One could build all of the commonly used wall representations, complete with fills, cavities and pre-assigned (but editable) thicknesses.
Pick your type and draw!
5 answers to this question
It's called the Wall Type Tool using the Select Wall Type command.
It's available in VW Architect and VW Landmark only. It's not an element of VW Foundation.
Is it possible to purchase the Architect components to add onto the base VW app. or is that an upgrade process?
the other options is good old scripts.
each wall style you want as a script.
and they float in an easy to find palette.
just make them part of your standard drawing and they'll always be handly for to use.
where as the wall styles tool in ARCHITECT
you have to go to a menu comand ever time you change style.
Wall styles are in fact a part of VectorWorks, but they are limited to 10 styles in VectorWorks and don't do all the data and record stuff that the same tools do in VWA.
