  • 13
More options for folders in the resource manager
livespace josha
13 answers to this question
....and:
There are some items (Chamsys MQ500 lighting console comes to mind) have symbols within that symbol. ...and gradients ...and textures ...and record formats
I'd love to have a "Lighting Control Chamsys MQ500" folder in my resource manager holding everything related to that imported resource.
Maybe a "Nest all imported object into single folder" option when importing that resource?
  • Like 4
On this line - when saving plants and landscape areas to a shared workgroup, we are finding that we end up with two instances of a plant object in the workgroup, if we have individually placed a plant and also used it in a landscape area. The saving of the landscape area automatically creates a nested folder of plants and saves the plants within the area there. Which is sort of helpful, but we'd like to be able to tell it to save them into the 'plants' folder, so that we don't end up with duplicates, and not knowing which is most up to date / having to remember to replace both if we make a change we want to save.
In my very limited understanding, the reason the folders are "typed" by "things" is because each "thing" involves a different data type. So line types involve one type of data, textures another, and records another. Higher level objects call these different data types into their geometry/settings as specified, which is part of what allows for their customizability. Hence all the "zNested" folders.
I agree with the spirit of posts that VW has not quite dialed this in for industry use cases. The design of the RM is really more of a file browser, so "general folders" would actually be drawings stored somewhere in user defaults. I find that even with understanding this philosophically, my resource management is a hot mess.
One solution to the "mix and match" request is tags. I am able to add tags to individual resources, however I don't seem to be able to filter by tags. I am unsure what the logic is here in terms of interface design.
PWF
I have a slightly different take on why there are different types of symbol folders. Perhaps if we offer enough theories, someone from VW will stop in and tell us which is closest to the truth 😉
A long long time ago (I can still remember when), VW had a concept they called "Default Content". That name has been basically dropped, but the idea still exists in the program.  When you use the Wall Tool (or many other tools), you can pick the Wall Style that you want to use from the mode bar. In order to not have to look at every resource in every file, I believe that VW only looks at items in the appropriate folder type in open files to provide the selectable styles.
I know that for items in the Application, Workgroup, and User folder you have to store the VWX file containing those resources in the correct folder path. I believe that Resource Manger folders are kind of an extension of that file finding requirement.
Let's see if we get any response to our theories.
Just yesterday I was praising the fluidity of the Resource Manager & how quickly and comprehensively the search is. (Although including misspellings in the search would be a welcome improvement even now)
I remember when you may as well gone to make a cup of tea anytime you wanted to search the old Resource Browser. I suspect the Folder structure was set up then as a way to try and optimize the horribly slow search.
Bringing up this thread for the issue of wanting to put a worksheet in the same folder as a symbol.
I am currently building out a workgroup library for my department and would like to include a worksheet with inventory counts several symbol folders deep, where the information will be most relevant, but am unable to mix and match types.
On 1/31/2024 at 8:20 AM, livespace josha said:
This limitation seems arbitrary and limiting for no reason*.
Speed and responsiveness is the reason! A lot of work went into designing the content folders so that every tool from any distributor or 3rd party would have a home.
We keep different types of resources in separate folders for the speed of the popup for choosing that type of resource. It makes it fast for that popup to open and close, etc.  It can help a little with search, too...if you have the RM resource type set to something other than 'all', type (and folder type) is one of the inputs to search and we have fewer items to dig through. Though mostly the search is faster now because we use a database containing a few things like name, tags, type.
The design is that Search is the 'filter', and tags are your ability to make custom filters. There are even people that add misspelled tags for when they mistype in a search.
This response feels like a cop out in terms of basic UI. Yes you can type "tag:<yourTag>" into a search bar and find your resource. This is generally something you learn at the intermediate level after many hours of usage. Expensive software should shorten the many hours curve.
Every modern file browser interface, from Finder to Explorer to task managers and code editors, includes a specific button for filtering and displaying tags. With such a feature, you don't have to include "misspelled tags" because you can correct the mistake once you see a populated list. The closest VW comes to this are the tag lists in the organization panel. This capability, in addition to the RM being able to call mixed resources based on a selected tag, would be incredibly useful.
