Rendering Gobo Projections
lalcaraz
quote:
Originally posted by lalcaraz:
I am attempting to render Gobo Projections using the Gobo Projection tool and I am using Custom Renderworks set to all of the settings that the Spotlight Manual tell me to set but still am not seeing the Gobos
Any ideas?
Thanks
Which version of SpotLight are you running? In SpotLight 9 try using the final quality renderworks mode and see if that works correctly.
  • 1 month later...
Kevin
I am running Renderworks 9 and Spotlight 9.5
I tried the Final Quality Renderworks also but it did not work
Thanks
Lonnie
I'm also having this problem. The blanc spot is projected without gobo image. In the object info, there is no gobo 1 or 2 fields at all.
PS: I'm using a mac version, if it does matter.
