In using the VWA 10 Set-Up Assistant, it creates a "matrix" of classes, layers and sheets with a possible combination of 6,000+ choices for a simple 4-story office building (or what used to be simple...). So, now we need a dedicated Management Assistant to figure it all out and help with the 3 different pull-down, pull-up and scrolling menus. If we were to use the VWA system in its current manifestation, we'll need an additional employee dedicated as comptroller for classes and layers, to help with the selection of the proper point-in-matrix space on which to draw any given item.
If not a management assistant, are there any ideas on how to manage the extensive VW system? Is anyone effectively using the VWA set-up assistant? per its designed intention?
skoorbb
28 answers to this question
