Window Opening Not Showing in 2D
Sky
I'm putting a new wall in front of an existing window with an arched opening. When the window configuration is "Opening" or "Cased Opening", it doesn't show the opening. If I set it for any other configuration, it is visible.
Is there a setting to make an "Opening" show in the wall in 2D?
I think I had my cursor hovering on the existing window, but you can see the blue handles for the selected window. The Object Info also clearly shows Configuration: Opening. I worked with that windows for 10 minutes trying to get it to display so it definitely isn't a selection issue.
