Iainy1961 Posted January 7 Share Posted January 7 I'm at the the point of cancelling my subscription. Nothing makes logical sense in Vectorworks. I have been trying to learn this program for months now, just as I think I'm getting somewhere and attempt to draw a 'real life' show instead of test stuff, something else happens which I spend hours trying to find out what I did wrong. This time, I don't think I have done anything incorrect, but, I obviously have. (the obviously here is very much facetious) First on a test plot; Perfect The next day: What am I doing wrong this time? Both are exactly the same. I feel it's just not worth the time and effort. I know I'm moaning but I have been using Light Converse, Cad and other drawing programs for a couple of decades now. I just can't get my head round some of the syntax in this program. I do read the manuals, I do look at the forum post and I do follow the lessons. But man, why does stuff like this happen? Anyway, if someone could point me in the right direction, I would be most grateful. Thank you, Iain Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted January 7 Vectorworks, Inc Employee Share Posted January 7 If you can post a file, we can take a look. 1 Quote Link to comment
Iainy1961 Posted January 7 Author Share Posted January 7 Thank you. I know I have done something silly. Just very frustrated. Bisc ver101.vwx Quote Link to comment
markdd Posted January 7 Share Posted January 7 It is because you also have Unit Number and Universe checked as well. The Universe and DMX address won't play well together in one operation. Best just leave the DMX and Unit fields checked and the Universe will number itself. 2 Quote Link to comment
Iainy1961 Posted January 7 Author Share Posted January 7 Thank you. Once again you guys here rescue me. Thank you again 2 Quote Link to comment
markdd Posted January 7 Share Posted January 7 That particular slip-up gets everyone from time to time. It would be so much better if the Spotlight Numbering DIalog opened showing all of the Parameters at once, or some indication that more than one field is checked for numbering. @Scott C. Parker Perhaps a future enhancement? Especially as it is such a common mistake. 2 Quote Link to comment
Mark Aceto Posted January 7 Share Posted January 7 @lainy1961 that dialog will also pick up where you left off numbering so you have to pick a different field, start at 1, then pick the field you want, deselect the other field, then start at 1… it’s a mess but it works if you go through that rigmarole. Sadly, it’s been that way for years. Bug’s been submitted. Maybe it will get fixed someday… 1 Quote Link to comment
Sam Jones Posted January 8 Share Posted January 8 18 hours ago, Mark Aceto said: you have to pick a different field, start at 1, then pick the field you want, deselect the other field, then start at 1… it You can just edit the start field to start at the number you desire. 1 1 Quote Link to comment
Mark Aceto Posted January 8 Share Posted January 8 2 hours ago, Sam Jones said: You can just edit the start field to start at the number you desire. One would think… 1 Quote Link to comment
Iainy1961 Posted January 9 Author Share Posted January 9 On the same subject as before, why aren't these the same? Is there a button to sync the two resources? What HD folder should Vectorworks be referencing to? The user data folder in preferences says it is tied to a folder that doesn't exist in my hard drive. Should I change that to the actual application folder? Will that get the resource manager and resource picker thingy (I don't know its proper name) to sync? I have spent two hours trying to put the logo onto a video screen. I have looked at help and forum posts but nothing works. I just don't know which HD folder Vectorworks is referencing. Quote Link to comment
markdd Posted January 9 Share Posted January 9 (edited) If you want to add a Logo to a Video screen, then you need to make your own Renderworks Texture resource. An Image resource like the one you are showing will not work. The Video Screen will come with a stock Texture resource called Vectorworks Logo RT. This will already be displayed on the screen as you have no doubt noticed. My advice would be to duplicate that texture resource and follow the workflow for editing images within a Texture. It is very straightforward and should take just a few seconds. Right-click on the duplicated texture and select Edit. Under the Color shader menu you will see Image displayed. Click on the Edit button and select Change image. Select Import an Image File and then navigate to the image on your machine that you want to use. Then press Open and OK and OK again and the Image will be loaded onto your Video screen. There are a few rudimentary controls within the Video screen plug-in to change the position and scale of the image, and then you should be done. Edited January 9 by markdd 1 Quote Link to comment
Iainy1961 Posted January 9 Author Share Posted January 9 Thanks for your swift reply. I did read about how to do all that but my problem is the resource manager and the window that pops up in the texture edit are not synced. I imported the image I want to use into the resource manager, even made a folder for other bits and pieces for this show, however that folder and many others are not aligned with the window that pops up. (I don't know its correct name but the one that looks like the resource manager but isn't. ) This is what I mean Why can't I see that folder? Thank you, Iain Quote Link to comment
markdd Posted January 9 Share Posted January 9 You are currently looking in your favorites folder. Try clicking on the Textures Folder.....? Quote Link to comment
Iainy1961 Posted January 9 Author Share Posted January 9 But it doesn't show the folder here. Quote Link to comment
markdd Posted January 9 Share Posted January 9 The Bits2 Folder contains an Image Resource. The Video Screen is looking for a Texture Resource. I think that is why you are not seeing the folder. I think that the Edit Screen Image is probably misleading you into thinking that you are looking for an image resource when in fact you need to look for a Renderworks Texture. 1 Quote Link to comment
Iainy1961 Posted January 9 Author Share Posted January 9 So I put the image into the texture folder? Quote Link to comment
markdd Posted January 9 Share Posted January 9 You can't put an Image resource into a Texture Folder. Have you made the Renderworks texture with your custom image yet? 1 Quote Link to comment
Iainy1961 Posted January 9 Author Share Posted January 9 Nope. Just trying to put it in that folder. I will look up how to do that. This program almost drives me to tears. I Light Converse if I want a drape, I make a drape, put the texture I want in it, type in the size and its there. Here, it's like a epic battle just to find a curtain, and then to size it etc. I also know its my lack of understanding because I have seen some fantastic drawings come out of Vectorworks which is the reason I am trying to learn it, but man oh man Thank you so much for your help and patience. Quote Link to comment
