3D Door ID Tags Only Visible on One Side
Kerisha
6 minutes ago, Kerisha said:
How do we show the 3D door / window tag on both sides. It only show on external elevation of the door / window.
If the hinge marker shows on both sides. How could we show the 3D ID tag on both sides?
You can't do this with the built-in ID tag but you can if you use a Data Tag instead, which is what most people use these days anyway I think (I do).
Logic is that the window/door only needs to show the label on one side, being the exterior view only, because that's how schedules and window labels usually work on elevations.
Have never seen an internal room elevation show the window label.  Duplication of information.
Understood thanks for your insight 🙂
