Stake object elevation display with a plus sign and without a dash
Happy new year to everyone.
Is there a way to display the stake object elevation so that there is only a plus sign followed by the elevation value? I can't get rid of the dash:
Displaying the dash is not an option due to regulations.
Thanks.
Have you tried to use Style: Cross and deselect Display Leader Line? Label reference Elevation. The cross will replace the + in this case, and it will also mark the exact location for the Elevation point. But of course you loose some flexibility in placing the label as you need to have the label close to the cross. The Label Position can be right or left...
Well that does work, sort of!
If I set line thickness to .5mm in the attributes palette, the cross looks like a plus sign:
No leader line though like you say.
Thank you!
