spettitt Posted December 16, 2023 Share Posted December 16, 2023 There is a worksheet function I'd like to use in a script. My script is performing a task on a list of selected ConnectCAD Circuit objects, and I want to get the Y Coord of the Source Socket to process the sockets in the desired vertical order. ObjectData(eval circuit source socket) exists, which sounds exactly what I need. I know how to use it in the data manager, but can these ObjectData functions be used in scripts? Also, I'm trying to return the Y Coordinate of the Socket, which I believe is a function. I don't know whether the ObjectData functions can only return record fields, or functions like Y Coordinate as well? If not, I may have to iterate a loop through all sockets to find the socket handle manually, but I'd rather not do that if possible. Thanks Quote Link to comment
Pat Stanford Posted December 16, 2023 Share Posted December 16, 2023 I don't think there is a way to use WS functions inside of VS/Python. Sorry. Since they expanded WS functions to Data Tags, maybe it would be possible to allow this in scripts also. But the problem would be identifying the object. The WS Functions works well with DataTags because the tag specifies a specific item just like a database subrow. For a script, there would have to be an additional step to identify the object to be evaluated. And probably error checking to make sure the object is valid. But a nice thing for a Wish or VE though. Quote Link to comment
spettitt Posted December 16, 2023 Author Share Posted December 16, 2023 Thank you Pat, no worries. I will have a go at seeing how efficient I can make this using more manual way I've used before. I'll think about it some more and I might VE. Cheers Quote Link to comment
