BG Posted December 14, 2023 Share Posted December 14, 2023 We have just started working on a new project. The file is only about 50mb. We received a message today saying that the metadata is too large. We have only just started, are we going to get this on a regular basis as it's a bit of a pain? Is there anyway to prevent this happening? Quote Link to comment
Vectorworks, Inc Employee jblock Posted December 15, 2023 Vectorworks, Inc Employee Share Posted December 15, 2023 @BG can you send me a copy of the .vwxp file so I can investigate? Quote Link to comment
BG Posted December 15, 2023 Author Share Posted December 15, 2023 10 hours ago, jblock said: @BG can you send me a copy of the .vwxp file so I can investigate? Hi Joseph What is the best way to do that? Thanks Brett Quote Link to comment
BG Posted December 17, 2023 Author Share Posted December 17, 2023 On 12/16/2023 at 2:23 AM, jblock said: @BG can you send me a copy of the .vwxp file so I can investigate? Hi Try this link https://www.dropbox.com/scl/fi/nsrnngec5iyngftq8o5lj/2311-WD01.01.vwxp?rlkey=k8ainefxt7x9oeudj52zxo7o2&dl=0 Thanks Brett Quote Link to comment
B-McG Posted December 21, 2023 Share Posted December 21, 2023 Just for the record, (last week) I too got the same message after my first saveandcommit of a new vwxw file. I cleared the metadata and created a new vwxw file and had not seen the error repeated since. Quote Link to comment
BG Posted January 18, 2024 Author Share Posted January 18, 2024 On 12/16/2023 at 2:23 AM, jblock said: @BG can you send me a copy of the .vwxp file so I can investigate? Hi Joseph This message popped up again yesterday. Did you have a look at the file? What causes this to happen? Thanks Brett Quote Link to comment
Vectorworks, Inc Employee jblock Posted January 18, 2024 Vectorworks, Inc Employee Share Posted January 18, 2024 @BG Can you send me a version of the file where the metadata is large (before you clear it)? It looks like the version of the file you sent before was not in the problem state. I apologize for the delay, I missed the notification for your previous comment. Quote Link to comment
BG Posted January 18, 2024 Author Share Posted January 18, 2024 Just now, jblock said: @BG Can you send me a version of the file where the metadata is large (before you clear it)? It looks like the version of the file you sent before was not in the problem state. I apologize for the delay, I missed the notification for your previous comment. We've just cleared it unfortunately, so will have to wait until it pops up again. Thanks Brett 1 Quote Link to comment
BG Posted January 25, 2024 Author Share Posted January 25, 2024 On 1/19/2024 at 10:59 AM, jblock said: @BG Can you send me a version of the file where the metadata is large (before you clear it)? It looks like the version of the file you sent before was not in the problem state. I apologize for the delay, I missed the notification for your previous comment. Hi Joseph Just got the same message again. Here's a link to the project file before the Metadata has been cleared. https://www.dropbox.com/scl/fi/8j6wpt10ahu7x5asjb65v/2311-WD01.02.vwxp?rlkey=m0oesrrd9289t4ccacyc9qxso&dl=0 Thanks Brett Quote Link to comment
Vectorworks, Inc Employee Rick Berge Posted March 26, 2024 Vectorworks, Inc Employee Share Posted March 26, 2024 There's two things that accumulate in the Project File. The more of it there is, the bigger the file gets, and the slower it is to copy the data back and forth during checkouts, which means that the checkout itself gets slower. And refresh, and commit, etc. One is the history that you can see on the History tab of the Project Sharing dialog. It's purely for humans, if they care, and there's a button on the history pane that you can clear any time you feel like. It can also be cleared as part of the metadata process mentioned by your screenshot. The second item is detail on all changes by all users, ever. This gets used to know what objects to reconcile when you Refresh in a specific Working File. The project doesn't know what old un-refreshed working files might be out there, so there's no way for it to self-manage expiring and deleting the older change lists. During the metadata cleanup all the old change lists get wiped and that's why everyone needs to refresh first or grab new working files after. VW2024 is tracking more detail, so these lists are getting bigger, faster. In Update 4 we bumped the trigger for this dialog from 50k to 200k, so you should see it a bit less often again, and only minimal difference in filesize or delays between Update 3 and Update 4 at the fullest point before the dialog shows. 2 1 Quote Link to comment
Mickey Posted April 9, 2024 Share Posted April 9, 2024 On 3/26/2024 at 9:21 AM, Rick Berge said: There's two things that accumulate in the Project File. The more of it there is, the bigger the file gets, and the slower it is to copy the data back and forth during checkouts, which means that the checkout itself gets slower. And refresh, and commit, etc. One is the history that you can see on the History tab of the Project Sharing dialog. It's purely for humans, if they care, and there's a button on the history pane that you can clear any time you feel like. It can also be cleared as part of the metadata process mentioned by your screenshot. The second item is detail on all changes by all users, ever. This gets used to know what objects to reconcile when you Refresh in a specific Working File. The project doesn't know what old un-refreshed working files might be out there, so there's no way for it to self-manage expiring and deleting the older change lists. During the metadata cleanup all the old change lists get wiped and that's why everyone needs to refresh first or grab new working files after. VW2024 is tracking more detail, so these lists are getting bigger, faster. In Update 4 we bumped the trigger for this dialog from 50k to 200k, so you should see it a bit less often again, and only minimal difference in filesize or delays between Update 3 and Update 4 at the fullest point before the dialog shows. I am now getting this pop up error message. We've been using project files for years, since they were introduced, and this is the first time I'm seeing this. OK I accept that 24 is tracking more data and needs more space,, but I am on 4 and just started getting this. The pop up tells me to run the utility, but when I do it just gives me the pop up back at me. So we're stuck in this doom loop. I submitted a ticket but no one has responded yet. My next move is to call tech support and see if they can help. Quote Link to comment
