Cristiano Alves Posted December 6, 2023 Share Posted December 6, 2023 Hello, I draw one arc and apply a mirror on X and Y. My objective is to get a polygon/surface with these 4 arcs: How I can get this? Quote Link to comment
Pat Stanford Posted December 6, 2023 Share Posted December 6, 2023 How about the Paint Bucket (Inner Boundary Mode) of the 2D Polygon tool? 1 Quote Link to comment
Cristiano Alves Posted December 7, 2023 Author Share Posted December 7, 2023 9 hours ago, Pat Stanford said: How about the Paint Bucket (Inner Boundary Mode) of the 2D Polygon tool? Humm I tried but the results are strange: (And I need to delete the red cones too) In my experience with other modelling software, I have a tool "TRIM" to delete the lines that I don't want. On Vectorworks, I didn't find the correct workflow yet. For example another question: If I want to extrude a triangle I can't because I can't convert the triangle lines to a shape. How I can make it? Quote Link to comment
Tom W. Posted December 7, 2023 Share Posted December 7, 2023 1 hour ago, Cristiano Alves said: I can't because I can't convert the triangle lines to a shape. How I can make it? Modify > Compose will turn the three lines into a Polygon Quote Link to comment
Tom W. Posted December 7, 2023 Share Posted December 7, 2023 11 hours ago, Cristiano Alves said: Hello, I draw one arc and apply a mirror on X and Y. My objective is to get a polygon/surface with these 4 arcs: How I can get this? I think you can use Compose on this too. Quote Link to comment
Elite Exhibits Posted December 7, 2023 Share Posted December 7, 2023 FYI Compose should work - Make sure the end points touch exactly - arcs are often on bad behavior in VW Peter Compose Arcs.mov 1 Quote Link to comment
Tom W. Posted December 7, 2023 Share Posted December 7, 2023 Actually looking again at the screenshots they don't look like actual Arcs, they look like Polygons. In which case it might be a matter of Decomposing all four objects, deleting the unwanted lines then composing the 'arcs'... 1 Quote Link to comment
Cristiano Alves Posted December 7, 2023 Author Share Posted December 7, 2023 5 hours ago, Tom W. said: Actually looking again at the screenshots they don't look like actual Arcs, they look like Polygons. In which case it might be a matter of Decomposing all four objects, deleting the unwanted lines then composing the 'arcs'... It isn't necessary to use "decompose", compose makes what all I want. However, thank you for speaking to me about the Decomposer. I never used that before and after I tested Decompose realised that it is a significant feature too. Quote Link to comment
mike m oz Posted December 7, 2023 Share Posted December 7, 2023 Pat Stanford's suggestion is the easiest way to do it. If the arc ends intersect the paint bucket mode of the polygon tool works. Quote Link to comment
mike m oz Posted December 7, 2023 Share Posted December 7, 2023 13 hours ago, Cristiano Alves said: If I want to extrude a triangle If you draw a triangle using the Triangle tool then both the Extrude command and the Push/Pull tool can be used to give it a third dimension. Quote Link to comment
