matto Posted September 23, 2002 Share Posted September 23, 2002 can we get the mirror tool so that it doesn't convert dimensions from constrained to un-constrained. Quote Link to comment
0 Guest Posted September 23, 2002 Share Posted September 23, 2002 Can you give an example of where this is happening? Type of obejct, objects selected to mirror, etc. Quote Link to comment
0 matto Posted September 27, 2002 Author Share Posted September 27, 2002 well how do i put it you use the constained dimension tool to draw a dimension on two points that are different in both x and y direction, but that tool only dimension either x or y (n key in the standard workspace) mirror it, even with the vertical or horizontal mirror comands, or mirror tool with shift key down to lock it to 90? if you edit the dimension it redraws parallel to the two control points (just like the m-key dimension tool would). Quote Link to comment
matto
2 answers to this question
