I would like to have a "select saved sheet" pull down menu within the Edit Save Sheet dialog so that when editing more than one sheet on the same drawing, you do not have to click O.K. for each sheet, exit the dialog back to the drawing, then choose edit sheet and select a sheet all over again to get back into the dialog.
I t would be great if you could edit any sheet from within the dialog by picking the sheet name from a list and then click O.K. just once to accept all the changes rather than the exhaustive process of opening and closing the dialog eight times to edit eight sheets.
PeterT
6 answers to this question
