Serious Label Legend problems
After upgrading to 9.5 final release the label legends have given me some serious problems with both new and old files.
No matter what, the text never shows up. If a container is set for an attribute, the container is visible, but the number inside is not.
I just opened a plot I drew in 9.0.
1) the file opened and looks correct.2) select a unit, go to the object info pallette and change the unit number from 13 to 14 (or whatever)3) all text for that unit, channel and unit number disappear. (and I wasn't even editing the channel number).
Another trial:1) open the old 9.0 file and all looks good2) go directly to SpotLight menu and do a Refresh Instruments3) all those with degree symbols change to rectangles (known bug I beleive)4) all label text disappears (on ALL units in the plot)
This also happens with completely new files.
I upgraded via the Web Update, on a PC running Windows 98SE with 256MB RAM.
I'm worried that I'm the only one here having this problem and that I need to do a clean install.
[ 12-18-2001: Message edited by: Eric Chenault ]
Just found the ErrorLog entry from selecting a unit, going over to the OI palette and typing a unit number into the field and pressing return.
Warning: _782 _815 - An incorrect object is described.
Warning: _782 _784 - Handle variable is NIL.
Warning: _782 _791 - Handle variable is NIL.
Warning: _782 _792 - Handle to text object is not valid.
Warning: _782 _793 - Handle to text object is not valid.
Warning: _782 _798 - Handle to text object is not valid.
Warning: _782 _800 - Handle to text object is not valid.
Warning: _782 _799 - Handle to text object is not valid.
Warning: _782 _794 - Handle to text object is not valid.
Warning: _782 _801 - Handle to text object is not valid.
Warning: _782 _805 - Handle variable is NIL.
Warning: _782 _808 - Handle variable is NIL.
Warning: _782 _816 - Handle variable is NIL.
Warning: _782 _811 - Handle variable is NIL.
Warning: _782 _814 - Handle variable is NIL.
Warning: _782 _802 - Handle to text object is not valid.
Warning: _782 _823 - Handle variable is NIL.
quote:
Eric, Can you please e-mail me a copy of your original 9.0 file that is exhibiting these problems. I'm fairly stumped at this point as to why you're seeing these problems.
kmoore@nemetschek.net
Kevin, I sent you the file via email.
This morning I uninstalled the v9.5 I had upgraded to using the Web Updater and reinstalled using the FullUpdate installer (the mega download).
The label legend problems have been taken care of. It either is a problem with the WebUpdater or it became corrupt in the process. No signs of any error were mentioned at the time.
