livespace josha Posted November 8, 2023 Share Posted November 8, 2023 Working on a pretty complex truss "ceiling" with lots of trusses and hanging positions in various rotations and angles. Rather than try to adjust each hang in the DL, I'm trying to create a worksheet that lets me do it via data entry. Running into a few OIP fields that don't show up as options to enter into my worksheet. So far, I'm missing: Roll (not really necessary, but just an observation) Hanging angle Rotation Hinge angle Related: I can't edit the ZCoordinate of a hanging position via a worksheet? I've asked similar questions in the past, and somebody always helps out with a formula or line of text to add into the worksheet. Is there a master list of these somewhere for me to reference? Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted November 8, 2023 Vectorworks, Inc Employee Share Posted November 8, 2023 =XROTATION(), =YROTATION(), and =YROTATION() get you the Roll, Hanging, and Rotation, but they are Read Only Functions. ='TrussItem'.'HingeAngle' returns the Hinge Angle, but edits from the worksheet likely won't take. The main issue with attempting to edit the fields you mention in a worksheet is disconnecting objects from each other. As for a master list, are you familiar with https://developer.vectorworks.net/index.php/VS:Function_Reference You'll find a huge amount of resources there. This collection of forums will be helpful as well. Many scripting developers discuss how to create tools to manipulate VW objects. https://forum.vectorworks.net/index.php?/forum/4-customization/ Quote Link to comment
livespace josha Posted November 17, 2023 Author Share Posted November 17, 2023 Thanks @Scott C. Parker. On the topic of truss rotation... The center of "roll" is not in the center of truss. Screen grab below. 4 generic trusses pulled out of the stock Vectorworks library. Even though my Y value didn't change on any of these, the truss is moved 1/2 its width in the -y direction. My thinking is that if I "roll" a piece of truss, the physical location doesn't change, just its orientation. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted November 18, 2023 Vectorworks, Inc Employee Share Posted November 18, 2023 On 11/17/2023 at 9:07 AM, livespace josha said: The center of "roll" is not in the center of truss. True. It's based on the insertion point. I'm not saying this is good or not. Certainly, something to think about. Quote Link to comment
aheininen Posted November 21, 2023 Share Posted November 21, 2023 My 2 cents, roll should be from the center of truss not from insertion point. Sometimes when inserting trusses, one piece turns somehow to wrong orientation on truss line. To correct this you can not just input correct roll angle because that "throws" that piece out of that truss line. To correct wrong roll you have to fight system to snap to correct roll. 3 Quote Link to comment
livespace josha Posted November 21, 2023 Author Share Posted November 21, 2023 100% agree, AND the Z-elevation should also not change. The only thing that should change is it's orientation along it's centerline. I think this is a fine line between "technically" and "logically" correct. I think the way this works now is "technically" correct in terms of geometry and a 3d modeling workflow. But "logically", when I roll a piece of truss...I'll pick it up, rotate it 90° along its centerline, then put it right back on the floor where I grabbed it from. 2 Quote Link to comment
