tomm11 Posted September 2, 2002 Share Posted September 2, 2002 It would be good to have a shortcut for the Align/Distribute menu command. Maybe using the numbers pad with a modifier Quote Link to comment
0 tomm11 Posted September 3, 2002 Author Share Posted September 3, 2002 Yea Andy, I have that. What I was thinking of was: Cmd/shift 1 = lower left Cmd/shift 5 = center Cmd/shift 9 = upper right etc. I?m not sure of align left only etc. Maybe another modifier Quote Link to comment
0 Guest Posted September 6, 2002 Share Posted September 6, 2002 When you use the Align/Distribute command you have the choice to align and/or distribute. You can then select the location of which the objects will be aligned/distributed by. THe graphic in the dialog box shows you what the outcome will look like. Quote Link to comment
tomm11
3 answers to this question
