GatRed Posted November 7, 2023 Share Posted November 7, 2023 Hi, I need help to make an operation I think could be quite common. I’m working on a big project with an existing building. We received a really big IFC model of the building. I would like to classify the elements in different classes following the IFC - material - component 1 field, so I can defined attributes by classes and have a coherent representation of the IFC file in plan and sections. Is there a way of doing that by script ? - select objects - for each object (Object) : · get the class (ObjectClass) · get the IFC-material-component 1(ObjectIfcMaterial) - create class named ObjectClass-ObjectIfcMaterial - assign the class ObjectClass-ObjectIfcMaterial to Object For example in the attached file : There is a beam IfcEntity object. Its class is 3D.S-POUTRES and the IFC material component 1 is Acier structurel - S235 The goal would be the automatically assign a new class named 3D.S-POUTRES-Acier structurel - S235. Does someone can help me with that ? (maybe @PatStanford?) Thanks ! Vectorworks Script.vwx 1 Quote Link to comment
GatRed Posted November 7, 2023 Author Share Posted November 7, 2023 I manage to make something with marionette. But I had some trouble with the concat node, it doesn’t concatenate each item of lists to make a list result. for example 3 lists : A; B; C with for each 3 items inside : 1, 2, 3. If I use the concat node the result is a string : A1 A2 A3 B1 B2 B3 C1 C2 C3 and I wanted to have one result list : A1 B1 C1, A2 B2 C2, A3 B3 C3. @Marissa Farrell did I miss something ? I found a concat node made by @DomC which does what I needed (thank you !) Here is the file with the result. If anybody has some improvement to suggest… Vectorworks Script.vwx Quote Link to comment
