jnr
VW Architect title block defaults
Perhaps when using the set-up assitant to script a set of documents, the drawing borders and title block should default to the sheet size selected. Most of us mortals can't remember con doc sheet size designations and would apppreciate it if these two variables would default. For example if I choose a D size sheet in the page set-up, make the title block sheet default to the con doc D size so that it corresponds to the page size chosen. Can this be that hard to write? If so, then what about an error message like (You have selected a title block that is larger or smaller than the page size,woul you like to correct this or continue with this choice?)
And two more things. The stair tool is way less than stellar and could use improvement (more options). Manipulating a wall once it has been drawn is a pain in the rear, if not impossible. Go look at Archicad's wall tool to see a better way of doing this.
0 answers to this question
