Dendecko Posted October 6, 2023 Share Posted October 6, 2023 Question, If I have a collection of objects I want to incrementally adjust the angle to. is there a function that will do that? I tried to search but couldn't figure out the write nomenclature to make the answer come up. Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted October 7, 2023 Vectorworks, Inc Employee Share Posted October 7, 2023 Hello, Select the object(s) and double click the Rotate tool in the Basic toolset. You can then enter an angle. The precision by default is two decimal places but that can be changed in the Units dialogue. Cheers, Peter Quote Link to comment
Dendecko Posted December 19, 2023 Author Share Posted December 19, 2023 Will this rotate each object in an increasing amount or will I still need to select and change the rotation for each one? Quote Link to comment
Chris Fleming Posted December 19, 2023 Share Posted December 19, 2023 I was just browsing the forums and saw this thread. Doing as Peter suggests will change the rotation of all three as a group. If for instance, you had 3 square columns that you need to rotate upon themselves, you'd have to do them individually, unless I'm missing something. If however, you want the collection to rotate as a whole, Peter's method works great. I hope that makes sense. Quote Link to comment
Boh Posted December 19, 2023 Share Posted December 19, 2023 There is a custom script that does this which I got from this forum years ago. I tried export it from my vw but the plug-in manager doesn't seem to be working atm otherwise i'd share it. Perhaps search the forum? Quote Link to comment
