Visualization to show wall stud thickness
I would like to us visualization to show all 2x4 studs, 2x6 studs.  I cannot find a way to have the visualization identify what wall uses 2x4 and 2x6
Any thoughts.  Below is using visualization to ID fire rating.  I would like to do the same for stud thickness.
this would be an internal review not construction documentation
I though i could use the "Function User-Defined or the wall style name.  But i cannot find how to add these to the Visualization tool
Thank you
To colour the Walls based on style name:
Or various IFC fields will return the same data ('Reference', 'ObjectType', 'Name', 'Description'...)
I'm not sure where the 'Function' data is stored...
Another option is to colour them based on the 'Description' field in the Data pane:
Lots of options...
