J. Wallace Posted September 29, 2023 Share Posted September 29, 2023 I have a question for those more familiar with the data visualization tool. I have only used this a few times, but it seems like a very powerful tool. In the example below, i printed out a pdf of a design sheet, which I finished up late yesterday. When I opened the file this morning, the file was as I expected it to be, except the data visualization effects were gone. When I click on the viewport and go under the data visualization tab, it does not list the settings I created the day before. Any help would be much appreciated. Screenshots below show last evening's and this mornings results. Quote Link to comment
Tom W. Posted September 30, 2023 Share Posted September 30, 2023 Did you definitely save the file you were working on the day before? Have you definitely opened up the right version of the file in the morning? That is the only explanation I can think of for what you're describing. When you create a new Data Vis it is automatically saved in the current file. And I have never known a VP to 'loose' a Data Vis that has been applied to it. One thing you can do is export a Data Vis to your user folder so that it's accessible from any file if they are settings you think you might use again (go to 'Manage Data Visualisations...' - not sure if different in VW2024 haven't checked yet). However this doesn't alter the fact that a Data Vis saved in your current file should still be there - like anything else in that file - when you close it + open it again, unless it wasn't saved... Incidentally one other thing I have found - but not relevant in your case - is that a Data Vis saved in the user folder when brought into a new file often (always?) doesn't work immediately: you have to 'wake it up' by renaming it or editing it. I have never tested this properly to determine exactly what's going on in order to file a bug about it. Be interested to know (highjacking your post!) what others say. Have you mentioned this before @Mark Aceto? Perhaps it's just me missing something. 1 Quote Link to comment
Mark Aceto Posted September 30, 2023 Share Posted September 30, 2023 1 hour ago, Tom W. said: Have you mentioned this before @Mark Aceto? Perhaps it's just me missing something. I haven’t had this issue before (although I have had frustration with how the Data Manager saves / stores / manages Data Sets). All of your questions / troubleshooting steps make sense. Users can even import Data Vis rules from other files. It’s pretty bulletproof. Also wondering if it’s a Project sharing situation… Is there a VW backup file or a Time Machine backup that could be accessed? Is this 2024? Is it an Unstyled SLVP? Are the DV settings visible from the View Bar on a design layer? 2 Quote Link to comment
Tom W. Posted September 30, 2023 Share Posted September 30, 2023 4 minutes ago, Mark Aceto said: I haven’t had this issue before Hmm I wonder what's happening in my case then will have to look at it... Quote Link to comment
Mark Aceto Posted September 30, 2023 Share Posted September 30, 2023 Also what about other SLVP’s? Wondering if that one went currupt, it’s a bug or something else… I would check everywhere I can find Data Viz. Maybe even open a new fresh file, and try to import from this one. Quote Link to comment
J. Wallace Posted October 1, 2023 Author Share Posted October 1, 2023 Thank you @Tom W. and @Mark Aceto I played around with this a bit more and exported the visualization to my user folder. That seemed to fix the issue. I'm not sure why this does not auto-save to the file itself, but I'm happy I can now use this powerful tool and not lose my work. Thank you both again. 2 Quote Link to comment
Mark Aceto Posted October 1, 2023 Share Posted October 1, 2023 Glad that worked out! I was deep in Data Viz today, and grabbed a screenshot of what I was talking about (importing from another file): Also, here's a reminder to Migrate them when the time comes: 2 Quote Link to comment
J. Wallace Posted October 1, 2023 Author Share Posted October 1, 2023 Thanks @Mark Aceto that was very helpful. Take care. 1 Quote Link to comment
Tom W. Posted October 26, 2023 Share Posted October 26, 2023 On 9/30/2023 at 9:07 AM, Mark Aceto said: On 9/30/2023 at 7:40 AM, Tom W. said: Have you mentioned this before @Mark Aceto? Perhaps it's just me missing something. I haven’t had this issue before This is definitely a thing for me. Happens every time with Data Visualizations saved in my user folder. At first it looks like the data vis has taken but once the VP as finished updating it disappears (apart from the damned legend of course). I have to edit the DV + pretend to edit the criteria then come back to the VP + now it has taken. Quote Link to comment
Mark Aceto Posted October 26, 2023 Share Posted October 26, 2023 6 hours ago, Tom W. said: I have to edit the DV + pretend to edit the criteria then come back to the VP + now it has taken. Having deja vu but this is a common workflow with one of my Data Manager mappings. I have to go through the motions of recreating the exact same function (character for character) the way VW wants me to (by picking from a list of pulldowns), and then it will work. Has been this way as long as I've had that mapping which is at least 3 releases. Anyway, I'll report my bug if you report yours. Quote Link to comment
Tom W. Posted October 26, 2023 Share Posted October 26, 2023 9 minutes ago, Mark Aceto said: Having deja vu but this is a common workflow with one of my Data Manager mappings. I have to go through the motions of recreating the exact same function (character for character) the way VW wants me to (by picking from a list of pulldowns), and then it will work. Has been this way as long as I've had that mapping which is at least 3 releases. Anyway, I'll report my bug if you report yours. I've seen that too with the Data Manager but I don't use it enough to feel confident I know it's not something I've done... And I'm still not sure whether the issue with Data Vis isn't down to me somehow either, given that no one else seems to have mentioned it. Is there someone from VW we can ask on Forum before filing a bug? Quote Link to comment
Mark Aceto Posted October 26, 2023 Share Posted October 26, 2023 (edited) 16 minutes ago, Tom W. said: Is there someone from VW we can ask on Forum before filing a bug? I would just submit it, and let them see if they can replicate it. Share the file you're having issues with, any screenshots, and be as descriptive as possible. It's a bit like taking your car to the mechanic because if it doesn't make that noise (they can't replicate it), it won't get fixed. Quoting someone else (I keep this reminder as a template for submitting bugs), include: A sample file A screen video or screen shots An itemized list explaining how to reproduce the bug A description of how things should work — that is, clear criteria for how to know when the issue is resolved For example, something like “draw a rectangle, press delete, see the warning” might seem obvious, but if there’s a test file with a rectangle and a screen shot of the warning, that will increase the speed with which it’s fixed. Edited October 26, 2023 by Mark Aceto Quote Link to comment
