Mat Caird Posted September 18 Share Posted September 18 (edited) Hi All How to display a roof hatch in top/plan view, with the hatch correctly aligned with the roof plan? Using the roof tool, not the roof face tool. I have the class options set to use at creation, with the fill set as the hatch, and the render texture surface hatch set to the same. If I render the top view in hidden line, the hatch displays correctly as expected, so it's only top/plan view giving me grief. Thanks, Edited September 18 by Mat Caird clarification Quote Link to comment
Jeff Prince Posted September 18 Share Posted September 18 I'm not sure if you can do that with a 2D hatch if it is a single roof object. If it is broken into roof faces, you could use the Attribute Mapping Tool to rotate the hatch for each Roof Face. Hatches don't respect the 3D map orientation like textures do. Hopefully someone else with more knowledge will weigh in. 1 Quote Link to comment
Tom W. Posted September 19 Share Posted September 19 6 hours ago, Mat Caird said: How to display a roof hatch in top/plan view, with the hatch correctly aligned with the roof plan? Using the roof tool, not the roof face tool. As Jeff says the only way is to Ungroup the Roof into separate Roof Faces + use the Attribute Mapping Tool or Local Mapping in the Attributes Palette. I'm pretty sure you need to make the Roof Face Unstyled as well in order to edit the mapping. Or at least that's always been my experience. 1 Quote Link to comment
