Data Tag Field Syntax - Order of Operations
I am trying to build a data tag that completes a two step equation in the order i want.
The math i would like to have is:
(Door.width-Door.leafThickness) / 0.2
(A-B) / C
Here is the field definition that i currently have:
(#Door#.#Width##in_0_0#-#Door#.#DoorThickness##in_0_0#) / 0.2
The issue is that I cannot seem to use parenthesis in order to specify to complete the subtraction prior to the division.
This seems basic so hopefully i am just missing something and this will be a quick solution.
Thank you!
Okay, still knocking my head against the desk on this one.. for some reason now this operation isn't working..
#PERIM##in_2_0#/24+0.49
The definition works up until the '/24' but will not add the 0.49 or anything for that matter. I recall in another thread seeing an issue when the perimeter is read as a number rather than a distance, but i need to keep it in inches and if i use 'doc_dist' it displays the perimeter in Ft'-in" format and i cannot seem to then convert it back into just a number.
Thanks!
