acardoza Posted September 15 Share Posted September 15 On the linked text fields (Ex: Device Name) on the new 3D connector panels it seems like there is a solid white fill behind the text even if you change that attribute in the device. Is there a way to remove the white fill? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted September 18 Vectorworks, Inc Employee Share Posted September 18 Hello @acardoza, Can you please share a test file showing the issue or a screen recording? My suggestion is that you are probably talking about some linked text and in order to change its attributes you have to change them for the text itself, but I will be able to tell you for sure once I can see what exactly is happening. Thanks, Nikolay Zhelyazkov Quote Link to comment
acardoza Posted September 18 Author Share Posted September 18 I have been changing the fill attribute for the text box in the panel layout edit, but when exiting the panel layout the fill returns. Is there a different way to achieve no fill on the text? Thanks Connector Panel Test.vwx Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted September 19 Vectorworks, Inc Employee Share Posted September 19 Hello @acardoza, You can control the attributes of this text by editing the class CC-Panel-Name. If you set the fill there to No Fill it will correctly apply to the text. Anyway, I think that this can be improved, so that the text inside the layout of the panel can have its own non class attributes if set so by the user, so we will think about improving this. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
