floring Posted September 8, 2023 Share Posted September 8, 2023 *newbie alert*don't know python*new to Vectorworks* If anyone can critique / improve this script, much obliged. The script is drawing a line. The following are the issues: 1. How to use PenLoc() correctly; now it is always returning 0.0, 0.0 (the center of the page) 2. How to tell a newly created class to "Use at Creation" 3. How to tell the plugin script editor to use spaces when tab is pressed? Strange beast this python is. Finally, anything else I do wrong, anything I could do better. Thanks y'all. import vs # Get the current cursor position # I'd really like to use vs.PenLoc() cx, cy = vs.GetMouse() # delect all items to avoid conflicts in the creation of this construction line vs.DSelectAll() # remember existing active class, go back to it when done with the construction line active_class = vs.ActiveClass() # Get the page width (it comes in inches) current_layer = vs.ActLayer() page_width, page_height = vs.TBB_GetPageArea(current_layer) pw = page_width * 24.5 # translate to mm ph = page_height * 24.5 # translate to mm # start x,y and end x,y of the line sx = -pw sy = cy ex = pw ey = cy # vs.Message("cx: {}\ncy: {}\npw: {}\nph: {}".format(cx, cy, pw, ph)) # create the line vs.Poly(sx,sy,ex,ey) # decorate the line, by creating a new class def class_change_callback(obj): # make sure line is not left selected vs.SetDSelect(obj) # line to be controlled by class vs.SetPenColorByClass(obj) class_name = "Ref Line" vs.NameClass(class_name) # create a new object # set color to class red = vs.RGBToColorIndex(65535, 0, 0) # vs.SetClPenFore(class_name, red) vs.SetClass(obj, class_name) # redundant: set line weight and color to object as I don't know how to 'Use at Creation' and let class control object vs.SetLW(obj, 1) vs.SetPenFore(obj, red) # revert to originally active class vs.NameClass(active_class) # Iterate through all objects in the document and apply the callback function vs.ForEachObject(class_change_callback, "INSYMBOL & INOBJECT & INVIEWPORT & (VSEL=TRUE)") Quote Link to comment
Marionette Maven Marissa Farrell Posted September 12, 2023 Marionette Maven Share Posted September 12, 2023 Hi! On 9/7/2023 at 10:42 PM, floring said: 1. How to use PenLoc() correctly; now it is always returning 0.0, 0.0 (the center of the page) According to the developer wiki, you have to use GetMouse for this. There's a note stating that PenLoc will only return the location of the pen within a script, not the location of the user's coordinate of the mouse. See PenLoc On 9/7/2023 at 10:42 PM, floring said: 2. How to tell a newly created class to "Use at Creation" Consider using SetClUseGraphic, SetClUseTextStyle, and SetClUseTexture On 9/7/2023 at 10:42 PM, floring said: 3. How to tell the plugin script editor to use spaces when tab is pressed? Can you be more clear with this? Are you saying that when you're typing code into the editor that the tab key is inserting a tab character instead of a set of space characters? Can you provide a short video demonstrating this? Quote Link to comment
Juliensv Posted September 12, 2023 Share Posted September 12, 2023 The Vectorworks script editor is very limited and as far as I can tell, does not offer the functionality to insert spaces rather than tabs in your code. It shouldn't be a problem because the python interpreter parses either one, as long you're consistently using only tabs or consistently using only spaces. This is annoying when you're copying code from other sources, but your only alternative is to use another code editor. Quote Link to comment
floring Posted September 13, 2023 Author Share Posted September 13, 2023 On 9/12/2023 at 11:58 AM, Juliensv said: The Vectorworks script editor is very limited and as far as I can tell, does not offer the functionality to insert spaces rather than tabs in your code. It shouldn't be a problem because the python interpreter parses either one, as long you're consistently using only tabs or consistently using only spaces. This is annoying when you're copying code from other sources, but your only alternative is to use another code editor. Thanks! Using another editor will still result in cut and paste I guess. Is there a way to link an external editor? Not mixing tabs and spaces remains the only option. Quote Link to comment
floring Posted September 13, 2023 Author Share Posted September 13, 2023 On 9/12/2023 at 11:42 AM, Marissa Farrell said: Hi! According to the developer wiki, you have to use GetMouse for this. There's a note stating that PenLoc will only return the location of the pen within a script, not the location of the user's coordinate of the mouse. See PenLoc Consider using SetClUseGraphic, SetClUseTextStyle, and SetClUseTexture Can you be more clear with this? Are you saying that when you're typing code into the editor that the tab key is inserting a tab character instead of a set of space characters? Can you provide a short video demonstrating this? Thank you for the reply! Any tip is greatly appreciated. GetMouse() is not accurate for my application. I think I understand what PenLoc() is meant for therefore it won't work. I scrapped this script and changed the approach. What I was looking for was reference lines to aid with creation of new items. With a shortcut. Next day I found the Guides under the Modify menu. Awesome. So I tried a new script, that would take a simple line positioned with precision and direction, and assigned it to Guides class, achieving my goal precisely. ChatGPT is atrocious with Vectorworks, yet it worked well with Python. Again, any correction is welcome. What is "Marionette Maven"? import vs import math # @florin, 09/12/2023 # find the page dimensions current_layer = vs.ActLayer() page_width, page_height = vs.TBB_GetPageArea(current_layer) pw = page_width * 24.5 # translate to mm ph = page_height * 24.5 # translate to mm # remember existing active class, go back to it when done with the construction line active_class = vs.ActiveClass() counter = 0 # not used message = "" # not used # per chatgpt, find angle between two points # where each point has an x/y coordinates set # these x/y coordinates are given by vw, via vs.GetSegPt1, vs.GetSegPt2 def find_angle(p1, p2): x1, y1 = p1 x2, y2 = p2 radians = math.atan2(y2 - y1, x2 - x1) return math.degrees(radians) # per chatgpt, project next x/y location given angle and distance # distance is calculated using page dimensions def project_point(x1, y1, angle_degrees, distance): # Convert angle from degrees to radians angle_radians = math.radians(angle_degrees) # Calculate the new x and y coordinates x2 = x1 + distance * math.cos(angle_radians) y2 = y1 + distance * math.sin(angle_radians) return x2, y2 def class_change_callback(obj): type = vs.GetTypeN(obj) global counter global message #types = types + ",{}".format(type) counter += 1 if type == 2: # 2 is type for line # get starting and ending coordinates cx, cy = vs.GetSegPt1(obj) dx, dy = vs.GetSegPt2(obj) # angles go in opposite directions angle1 = find_angle((cx,cy),(dx,dy)) angle2 = find_angle((dx,dy),(cx,cy)) #message = "{},{}".format(angle1,angle2) # start x,y and end x,y of the line sx, sy = project_point(cx, cy, angle1, (pw*ph)/2) ex, ey = project_point(dx, dy, angle2, (pw*ph)/2) vs.SetSegPt1(obj, sx, sy) # set next x/y in oner direction vs.SetSegPt2(obj, ex, ey) # set next x/y in oposite direction red = vs.RGBToColorIndex(65535, 0, 0) # red color vs.SetPenFore(obj, red) # set color of line vs.SetLW(obj, 1) # line weight vs.SetClass(obj, "Guides") vs.DoMenuTextByName("Lock",0) vs.SetDSelect(obj) # deselect the line # Iterate through all objects in the document and apply the callback function # vs.ForEachObject(class_change_callback, "INSYMBOL & INOBJECT & INVIEWPORT & (VSEL=TRUE)") vs.ForEachObjectInLayer(class_change_callback, 3, 0, 4); #{ Visible/Selected objects, Shallow, Editable Layers } #vs.Message("{}".format(message)) # revert to originally active class vs.NameClass(active_class) vs.SetTool(-240) # ensure Selection tool is active Quote Link to comment
Pat Stanford Posted September 16, 2023 Share Posted September 16, 2023 The standard way to use an external editor with Vectorscript (not sure about Python), is to use {$INCLUDE FileName.Ext}. Then you can edit the Included file in the external editor and only have to write the basic 3 lines of container code in the built in editor. Or maybe you can do it all with an Include which would make the internal editor code only a single line. Procedure Test; {$INCLUDE Filename.ext} Run(Test); Quote Link to comment
Peter Vandewalle Posted September 16, 2023 Share Posted September 16, 2023 In Python that'll be Import <path to file> The file path starts from the plug-in folder and doesn't need the .py extension. In most cases I use this script in the Vectorworks editor: import <path>.main as mod mod.main() The <path> just points to a folder in the plugin folder. The path folder contains 3 files: __init__.py main.py code.py The init file is needed to make the folder work as a Python module. It's just an empty text file names __init__.py The main.py file contains: def main(): import <path>.code as mod from importlib import reload reload(mod) mod.main() The code.py file contains a def called main that contains the actual code. 2 Quote Link to comment
Ben Garcia Posted January 9 Share Posted January 9 On 9/16/2023 at 9:38 PM, Peter Vandewalle said: In Python that'll be Import <path to file> The file path starts from the plug-in folder and doesn't need the .py extension. In most cases I use this script in the Vectorworks editor: import <path>.main as mod mod.main() The <path> just points to a folder in the plugin folder. The path folder contains 3 files: __init__.py main.py code.py The init file is needed to make the folder work as a Python module. It's just an empty text file names __init__.py The main.py file contains: def main(): import <path>.code as mod from importlib import reload reload(mod) mod.main() The code.py file contains a def called main that contains the actual code. This is an old post but I want to highlight I cannot find this information anywhere else, and it's really valuable. Quote Link to comment
