Moe_90 Posted September 1, 2023 Share Posted September 1, 2023 Hello everyone, I hope you are well. i posted that already in Site Design forum, but i though maybe here it will have a better chance. I would like to ask if there is a way to map the geometric information of an object, such as length, width, height, volume, etc.... to the required IFC date field How can I assign this information? Is assigning to a customPset an efficient workflow? thanks in advance for your help Quote Link to comment
Moe_90 Posted September 13, 2023 Author Share Posted September 13, 2023 so i did some research, and i found this formulas list, which is very helpful in my opinion.https://developer.vectorworks.net/index.php?title=Worksheet_Functions#Text and using expert formulas in the Data Manager, i can map the field i want to the info i want to show my problem now, is how can i add Units symbol to the data field? because the when i use the equation for length, it just map the value, and doesn't show the unit (m², m, kg, etc..) how i can add the Unit symbol to the formulas, any help? Quote Link to comment
