Door Hardware, Adding Categories to Hardware Set
I am trying to make use of the Hardware sets as part of Door Styles.
To really use the Hardware set I need to include some items that are not part of the standard options. Example, weather striping or card readers.  These could be dumped into the notes area but it would be nice to be able to include them in a proper format
The next step would be to format the groups with the items stacked
(rather than like a schedule where the items are all in one line (
Preferred
this seems to be the default
Thanks for the reply
i recall many years ago adding a field to an object but I do not recall the circumstances,  Your probably correct that we cant customize the hardware, it seems very locked down.
I did however have the same idea as EFA and added the field via a record.  It does work but adds a second step, that makes if feel a bit fussy.  just have to try it out to see how it works in a team setting.
also used a legend to format the hardware groups the way wanted.
Thanks for the input
I can move ahead with this but if feels a bit like a mish mash of data that requires some finger crossing.
image.thumb.png.7dbdd46ea1428e263a782499c67bb864.pngimage.thumb.png.8831d373bec13a1cd648b9c8c5197783.png
