reverb
Architectural Scale basics
The following scales should be available in the architectural scale area of the layer scale window:
3/32" = 1'-0"3/16" = 1'-0" 3/8" = 1'-0"
These scales appear on the standard triangular architectural scale that every draftperson, designer and architect possesses and should bestandard even in the most basic CAD program.
1 answer to this question
quote:
If you're using these scales a lot, it's pretty easy to create your own plug-in command to set it. Select "Create Plug-in", create a new plug-in of command type (naming it something like "Set Scale 3-16", select "Script..." and enter SetScale(32); {for 3/8"=1'0"}Use 64 for 3/16"-1', and 128 for 3/32".
