CipesDesign
Bring Back Left/Right/Center Wall Toggle
Please, please, please return the simple ability to use the command key to toggle between left/right/center when drawing walls & double lines. It's so simple and time saving. There are so many little annoyances in V9.x.x that slow down the environment already I cannot figure out why such a nice feature would be removed (or forgotten???).
Thanks- PLC Mac G4
2 answers to this question
Point taken.
Are you aware that you can use the 'mode groups' shortcut keys to cycle through the various wall placement options? In the standard workspace, the U key corresponds to the first group of buttons in the mode bar, and pressing it will cycle through them just as the Command key did in 8.5.2 for the wall tool. The I key does the same for the second group of buttons, the O key for the third group, and so on. You can customize these shortcuts using the third pane, "Misc. Keys," in the Workspace Editor.
The nice thing about using these keys is that they work exactly the same way for all tools. Using the command key to toggle through the options didn't work for all tools.
Caleb, Thanks! I was not aware of the U-I-O keys' functions and should have been. This will help a lot!
Peter
