Ron Kenyeri Posted March 9, 2004 Share Posted March 9, 2004 Had to reinstall everything this weekend my HD died. Once I got MacOS X 10.3 installed I installed VW 10 and got it upgraded to 10.5.1. So, all is well to this point. Next I installed CW 7 and following the readme, in installed the upgrade for 7.1 then 7.2, then I build the libraries, and then I added the carbonlib. All went ok, no errors, I've done this before. Then I go to build the VW libs so I can go back to work and I get the following error from CW 7.2: "Project "MasterCLibs.mcp" needs to be converted. Some target settings are in a newer, incompatible format. They will be initialized to the factory settings." Well I have never seen that before, but I clicked ok and tried it. As you may have guessed it did not work. When I compiled it I got the error: "Link Error : undefined 'main' (code) Referenced from '__start' in MSL_Runtime_PPC.Lib" So what did I do wrong? I upgraded to Mac 10.3 when I replaced the drive, and I also upgraded to VW 10.5.1. Are one of these components incompatable with the SDK? My current (and working) system was Mac 10.2 and VW 10.1.3, note before I had a full version of Mac 9.2 on my machine before now I do not. Any suggestions would be appreciated. Ron Kenyeri Quote Link to comment
Guest Posted March 9, 2004 Share Posted March 9, 2004 Are you using the lastest SDK for 10.5? Quote Link to comment
Ron Kenyeri Posted March 22, 2004 Author Share Posted March 22, 2004 Amazing!!! Installing the CORRECT SDK seems to solve my problems why did I not thing of that...... Thanks for pointing the obvious, sometimes its just to easy to get lost in the details. Thank, Ron Quote Link to comment
