Jrw Posted August 9, 2023 Share Posted August 9, 2023 Hi, I used 'ConnectCAD' > Drawing > Number Cables...to automatically number all the circuits. However some cable numbers are not shown on the drawing, they do have been numbered according to the circuit report. Also tried to use 'spotlight numbering' still not shown. See below - there are 4 circuits but there is only one number shown for the last circuit. Anyone know how can I fix this? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 9, 2023 Vectorworks, Inc Employee Share Posted August 9, 2023 Hello @Jrw, Can you try changing the Number Display option in these circuits to be something different than Auto and let me know if this fixes the problem? Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
Jrw Posted September 8, 2023 Author Share Posted September 8, 2023 (edited) Hi @Nikolay Zhelyazkov, Yes it kindly fixed the problem a bit but now the number is overlapping with the connector types...see below. I guess it was not shown originally because of this. Is there a way I can fix this? Edited September 8, 2023 by Jrw Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted September 11, 2023 Vectorworks, Inc Employee Share Posted September 11, 2023 @Jrw Try adjusting the Circuit Number and/or Connector Type offsets in ConnectCAD Settings dialog->General pane and let me know if this helps. Note, these changes will affect all the circuits in the active document. Quote Link to comment
Jrw Posted September 18, 2023 Author Share Posted September 18, 2023 Hi @Nikolay Zhelyazkov , Thanks it basically solved the issue. I wish it could know to adjust its location to the horizontal line instead of offsetting from the endpoint vertically 🤣 I guess it's good enough for now. Thanks. Quote Link to comment
