pmorberg Posted July 31, 2023 Share Posted July 31, 2023 Hi, I am new to Braceworks and have searched for a good solution, but I cannot find it. Is it possible to calculate the weight of a truss with two motors without attaching the top hook? Right now, it says, "The suspension point is not attached." I appreciate any help you can provide. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted August 1, 2023 Vectorworks, Inc Employee Share Posted August 1, 2023 The error message is telling you that the hoist is not correctly connected with the truss that should be hung from it. To check this select the truss, then right click on the truss and activate the 'select system objects' command from the context menu Everything attached to the truss line will be highlighted. This will show whether the hoist is correctly connected to the truss To reattach the hoist drag it off the truss and then back on at the desired location, making sure that the red autoconnect highlight displays Quote Link to comment
