Swales Posted July 20 Share Posted July 20 I've noticed that the aerial imagery provided within the GeoImage tool is of such a low resolution as to only be useful on the most high-level plans. Do you require an ESRI account in order to download higher resolution imagery? If so, which membership level is required to be able to access such imagery? Quote Link to comment
bcd Posted October 30 Share Posted October 30 I'm interested in this also - and also how to obtain ESRI heighmaps Quote Link to comment
Poot Posted November 13 Share Posted November 13 (edited) See the thread below. You may have to adjust the size of the area you are using for the geoimage to get better resolution.... but the last I checked it was still hard to get HD images (been awhile) Edited November 13 by Poot Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted November 21 Vectorworks, Inc Employee Share Posted November 21 Hello, All jurisdictions have access to different services with different resolutions. You should contact your local technical support for advice. Cheers, Peter Quote Link to comment
