Trouble creating an opening in a wall
I need to create an opening (not a door or window) in a wall. I thought I could simply draw a rectangle on the inner surface of the wall and then use the Push/Pull tool to create the opening, but that doesn't seem to be working. It's a 6" thick wall, and when I push/pull to -6", it doesn't remove the outer surface of the wall.
