veeresh.huvinahalli Posted July 3, 2023 Share Posted July 3, 2023 I'm trying to create the roof as shown above but I don't want to use any existing API for creating roof is there any way we can use only points/line data to get desired roof as shown above with different bearing height. Quote Link to comment
Gadzooks Posted July 4, 2023 Share Posted July 4, 2023 So this is a 2D drawing? How have you come to the geometry we see on this sketch? You have no other data - elevations drawn etc?? BTW, why is there - what seems so be - a roof edge shown if this layout is Top Plan? Marked here.... The time consuming way of prepping a (resultant) roof plan off plan/layout/elevational heights is to overlay your roof pitch lines (from different bearing heights as you state) and create the plan geometry - assume you do have the roof pitch?. That is pretty much basic 'technical drawing'. Providing a better insight into your reluctance to use a capable 3D software package for this might help someone guide you better...... Roof shown as I don't have wall data. Not sure you're going at this from the right direction. Seems much too cart before horse. Quote Link to comment
VIRTUALENVIRONS Posted July 4, 2023 Share Posted July 4, 2023 There are several ways to go about this, but I noticed you indicated Line data as one. If you created the outline of your shape with 3D lines. Then the following would be a potential solution. - After you have your shape outline in 3D lines. - Convert them to NURBS - Select the lines that form continuous planar surface (then the step below) - Go to 3D power pack and choose "Create Surface from curves (this will make solid planar surface) - when you have all your surfaces, you can use "Add solids" if you wish Quote Link to comment
veeresh.huvinahalli Posted July 4, 2023 Author Share Posted July 4, 2023 Basically, I will have wall in lines form as shown below in diagram below with the roof pitch and bearing height as shown to each side of line Quote Link to comment
Gadzooks Posted July 4, 2023 Share Posted July 4, 2023 (edited) So your first sketch was out since the rear pitch was not drawn with 45º lines (hips to ridge) - leading me to believe that pitch was steeper. You're also forgetting - correct me if wrong - the roof needs to overlap the wall extents This was sooooooooo easy to create - even with having to input your 'freedom units' changed to mm. You're going to have to grasp the nettle and draw in 3D Edited July 4, 2023 by Gadzooks Gables to hips 1 Quote Link to comment
Gadzooks Posted July 4, 2023 Share Posted July 4, 2023 Sorry - should have noted I used your new drawn layout as being correct since there were no dims given Quote Link to comment
veeresh.huvinahalli Posted July 4, 2023 Author Share Posted July 4, 2023 Thanks for the update on it, Is there any calculation formula/logic can we use to draw those lines on button click and create roof lines as drawn in new update image without any API reference. Quote Link to comment
Gadzooks Posted July 4, 2023 Share Posted July 4, 2023 You’re sounding like a student - yes? Quote Link to comment
veeresh.huvinahalli Posted July 4, 2023 Author Share Posted July 4, 2023 (edited) Yes😅 Edited July 4, 2023 by veeresh.huvinahalli Quote Link to comment
Gadzooks Posted July 4, 2023 Share Posted July 4, 2023 I’ll pm you rather than provide a basic geometry lesson to others. 1 Quote Link to comment
veeresh.huvinahalli Posted July 4, 2023 Author Share Posted July 4, 2023 (edited) Yes sure, Thank you for the support. Edited July 4, 2023 by veeresh.huvinahalli Quote Link to comment
