Marionette - get values/strings or formulas from a existing worksheet
Hello,
am I missing something?
I kind of don't get values/strings or formulas from a existing worksheet...
I tried different rows and columns but I don't get the expected values.
I can't figure out how I get the right "Handle to the Worksheet = hWorksheet
I can search with obj by crit (=worksheet) and get i.e. type #56 - is this the correct one?
Can I access a Worksheet inside the Resource-Manager? (by name?)
Cheers.
Item type 56 is the image of the worksheet on the drawing. You need an object type 18 which is the actual worksheet with the data.
I don't know how to get a handle to the worksheet based on the handle to the worksheet image in Marionette.  In Vectorscript there is a function GetWSFromImage(Handle_to_Image).
HTH
  • 2 weeks later...
If you know the Name of the worksheet you want and can hard code it you should be able to use the Name node.
Otherwise I don't see an existing node to get the Worksheet from the Worksheet image.
It should be a very simple node to create is you want to take a crack at scripting.
  • 1 month later...
