I have a file where the ‘Offset’ parameter for a styled Window is set to By Style in the ‘Plug-in Object Style Options’, but editing the value of that parameter is not carrying through to instances of that Window style in the drawing.
So for example here is the offset set to -183 in the PIO Object style settings for a Window but in the OIP it is showing -131:
To change the offset for multiple instances of the same style I am having to do it window by window in the OIP.
In a new blank test file it works fine so I guess something has become corrupted in this particular file, but I'm wondering whether it's something you've seen before @Matt Panzer + whether you have any nifty tricks up your sleeve for resetting things?
Thanks
BTW I have shut down VW, restarted the computer, run Repair - still the same
Tom W.
Thanks
15 answers to this question
