Michal Zarzecki Posted June 1, 2023 Share Posted June 1, 2023 Hi All, I noticed today that Area Increase Factor in Landscape Area settings doesn't seem to have an effect on the plant numbers in VW 2023. The instance on the left has AIF set to 1. On the right it's set to 2, but the number of plants is the same. Do I have to take any extra steps to make it work in this version? Also, if a Landscape Area is sent to surface AIF is disabled altogether. Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted June 3, 2023 Vectorworks, Inc Employee Share Posted June 3, 2023 Hi @Michal Zarzecki, I think you've found a bug for the calculation of Landscape areas on flat surface - I'll file a Jira on it. However, when you're using a site model, the calculation is automatically disabled, as the site model will take care of the increased surface area. Quote Link to comment
Kian Posted August 23, 2023 Share Posted August 23, 2023 Was this issue ever fixed? I'm having the same problem whereby the landscape area increase factor isn't working in 2023. I may have to go back to 2022 which isn't ideal. I'm also having problems in older files (2021) where the rate change doesn't even effect numbers. 1 Quote Link to comment
mocha Posted August 22, 2024 Share Posted August 22, 2024 I'm working with VWX 2024 - unfortunately, this problem still seems to be ongoing. 1 Quote Link to comment
