MartinBlomberg Posted May 31, 2023 Share Posted May 31, 2023 Hi,  If I have an object, a barrier for instance, with set dimensions, is it possible to "draw" lines with that object? I want all objects to be connected with each other and to attach to the very end point of each object. Like the truss feature, but with different objects.  Hope you understand 😃  Thanks!  1 Quote Link to comment
Kevin Allen Posted May 31, 2023 Share Posted May 31, 2023 well, some objects, like softgoods respond to the commend "create objects from shape" in the contextual menu or Modify>convert>convert objects.... Â you might also use the move by points tool 1 Quote Link to comment
markdd Posted May 31, 2023 Share Posted May 31, 2023 Yes, if you have the designer licence then the repetitive unit tool will do that. Quote Link to comment
MartinBlomberg Posted May 31, 2023 Author Share Posted May 31, 2023 2 minutes ago, markdd said: Yes, if you have the designer licence then the repetitive unit tool will do that. I do have Designer license but not sure what tool you mean... Can't find it. Quote Link to comment
markdd Posted May 31, 2023 Share Posted May 31, 2023 The Repetitive Unit Tool is in the Detailing Toolset of the Design Suite workspace. You may need to add it to your workspace..... 2 Quote Link to comment
MartinBlomberg Posted May 31, 2023 Author Share Posted May 31, 2023 14 minutes ago, markdd said: The Repetitive Unit Tool is in the Detailing Toolset of the Design Suite workspace. You may need to add it to your workspace..... Thank you! We're almost there, didn't know about this feature, I just added it to my toolbox.  Do you know of a way to draw object by object? Quote Link to comment
markdd Posted May 31, 2023 Share Posted May 31, 2023 No! I tend to do what I need to do and then Ungroup the object leaving just the Symbols arrayed one after the other. Â Quote Link to comment
MartinBlomberg Posted May 31, 2023 Author Share Posted May 31, 2023 20 minutes ago, markdd said: No! I tend to do what I need to do and then Ungroup the object leaving just the Symbols arrayed one after the other.  Alright, thanks! Something tells me that there's a feature like this in the move-command somewhere. I think AutoCAD had a feature like this. Would be great to have in VW as well 😃   Quote Link to comment
bcd Posted May 31, 2023 Share Posted May 31, 2023 A couple of alternative approaches. In 2d - a Complex LineType will possibly get you there In 2d or 3d you can DAP (duplicate along path) an object or Symbol Quote Link to comment
