Christian Fekete Posted May 22, 2023 Share Posted May 22, 2023 Hello, I cannot figure out why some joints are capped and not others. They are all defined with uncapped components, all on the same class and all uncapped walls on the drawings. Thanks for your help CF Wall join.vwx Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted May 23, 2023 Vectorworks, Inc Employee Share Posted May 23, 2023 On 5/22/2023 at 10:40 AM, Christian Fekete said: Hello, I cannot figure out why some joints are capped and not others. They are all defined with uncapped components, all on the same class and all uncapped walls on the drawings. Thanks for your help CF Wall join.vwx 6.85 MB · 2 downloads If the fills between two components in the join are different, you will get a line between them. I believe that's the cause in your file. Quote Link to comment
filip Posted October 25, 2023 Share Posted October 25, 2023 I can't find a sollution for connecting / changing the individual setting of differentcomponents of a walltype vertically, without affecting the whole wall type, so is there a way to change the wallsettings of the components for an indiviual wall without changing the wallstyle completely? best regards Filip Bosscher Quote Link to comment
taoist Posted October 25, 2023 Share Posted October 25, 2023 Try changing one of the walls you want with different material(s) to unstylized. Change your material(s) and either save as new stylized or leave as unstyled wall type. If I recall correctly, the Stylized walls will remain unchanged. Quote Link to comment
filip Posted October 27, 2023 Share Posted October 27, 2023 thanks taoist...I wil try to go with your flow. Quote Link to comment
filip Posted October 31, 2023 Share Posted October 31, 2023 Vectorworks has a good working tool for connecting horizontal walls and components of walls, was it to difficult to create a tool for vertical walls? Quote Link to comment
line-weight Posted October 31, 2023 Share Posted October 31, 2023 On 10/25/2023 at 11:23 AM, filip said: I can't find a sollution for connecting / changing the individual setting of differentcomponents of a walltype vertically, without affecting the whole wall type, so is there a way to change the wallsettings of the components for an indiviual wall without changing the wallstyle completely? What exactly do you want to change "vertically"? You can change the height of individual components in a wall object without affecting the wall style. If you want to change to a different construction type, at some point in the height of the wall, then you need to stack two different wall types on top of each other. Quote Link to comment
Tom W. Posted October 31, 2023 Share Posted October 31, 2023 Yes @filip it would be good to see some screenshots of what it is you're trying to do. Quote Link to comment
filip Posted December 18, 2023 Share Posted December 18, 2023 Dear Tom, this screenshot shows two walls and a floorslab, the walls are on different laters, and is would be great to connect the componentens seperately. Horizontaly there is a nice tool to do this, not vertically. see screenshot. 1 Quote Link to comment
